czy ktoś z klubowiczów miał juz z taką sprężarką doczynienia?? jak to wstaje i czym się charakteryzuje??
mam opcje kupienia takiej do nissana za bezcen w satnie idealnym[właścicielowi za mało 300km 420nm ]
szukam opinii o IHI VF36
- Coobcio
Zapewne siedziała ona w subaru... poproś właścicela o ten wykres 300KM i 420Nm i na nim będzie widać jak ona wstaje
Kod: Zaznacz cały
This is some information on IHI turbos that I've pulled from a few sites.
VF22
This turbo has the highest output potential of all of the IHI VF series turbos and is the best choice for those who are looking for loads of top end power. The top end power however, does not come without a cost. The VF22 spools significantly slower than the rest of the IHI models due to the larger P20 exhaust housing and large 40 mm compressor wheel. it is much less suited for daily driving than some of the other models. Although the largest VF series turbo, the VF22 is not quite optimal for stroked engines or those who wish to run more than 20PSI of boost. Utilizes a standard ballbearing center design. Recommended for use on cars with significant modifications and where flow capacity is more important then response time. Expect flows around 490 CFM at 18.0 PSI
VF23
This turbo is considered a great all-around turbo. Like the VF22 it utilizes the largest P20 exhaust housing. This housing is mated with a smaller compressor housing of the of the VF24 for fast response and excellent low and mid-range performance. It does not have the same top end power of the VF22, but spools up significantly quicker. Standard ball bearing center section. Excellent bolt-on replacement for the standard WRX turbo on cars without any other major modifications. Expect flows around 430 CFM at 18 PSI.
VF24
This turbo shares its compressor housing with the VF23 however, this housing is mated with a smaller (P18) exhaust side. The smaller characteristics of this turbo allow it to provide ample bottom end power and quick spool. This turbo is very popular for Imprezas with automatic transmissions and Group N rally cars. Not recommended for stroker engines or engines with high boost as turbo is small and can over speed. Best turbo for cars that want the best bottom end and least lag. Expect flows around 425 CFM at 18 PSI
VF28
This turbo came standard on the STi Version 5. In terms of overall size, it is smaller than the VF22, VF30 and VF34, and about same size as the VF23. Expect flows around 425 CFM at 18 PSI
VF29
This Turbo is nearly identical to the VF24, with the same compressor and exhaust housings. However the compressor wheel in the VF29 is has been changed slightly. The changes made to the compressor wheel in this model are generally viewed as improvements, and as such this unit is typically chosen over the VF24. Has a different location for the pressure hose on the waste gate actuator Expect flows around 425 CFM at 18 PSI
VF30
The VF30 is commonly considered the best bang for the buck turbo in the IHI VF series line. A relatively new model the VF30 features the same exhaust housing as the VF24 but a larger compressor side similar to the VF22. The combination of these two parts results in increased output potential without the lag associated with the VF22. Although it doesn't offer the top end supremacy of the VF22, the VF30 is a great compromise between these unit and the quicker spooling models. This is the ideal turbo for the average customer looking for fast excellent mid-range performance and response. This is not a ball bearing turbo as it utilizes a sleeve type design. Expect flows around 460 CFM at 18.0 PSI
VF34
The VF34 is nearly identical to the VF30, with the same exhaust housing and compressor. However the VF34 goes back to the ball bearing design, and in doing so achieves full boost approximately 500RPM sooner than the comparable VF30. The VF34 is the most recent IHI design and as such costs slightly more than its counterpart. Top end performance and maximum output are identical to the 30. Expect flows around 460 CFM at 18.0 PSI
VF35
The VF35 utilizes the same compressor housing as the VF34 however it also features a divided thrust or offset ball bearing design. The smaller P15 exhaust housing for quicker spool up and a slightly more limited top end. The compressor inducer size is the same as a VF30/or 34 turbocharger. This turbo is standard on the new WRX Type RA.
VF36
Roller bearing version of the twin scroll VF37, also has a titanium turbine and shaft for even quicker spool. Same compressor housing as VF30/34, however twin scroll P25 exhaust housing provides slightly better top end output due to reduced exhaust pulse interference. This turbo is good for 400HP and used on JDM STI Spec C from 2003 onwards.
VF37 (thrust bearing)
Enter the age of twin scroll IHI turbos. Same compressor housing as VF30/34, however has a new twin scroll P25 exhaust housing that provides slightly better top end output due to reduced exhaust pulse interference. Twin scroll also provides better spool up for improved low down response over the VF30/34. This turbo is good for 400HP and used on JDM STI from 2003 onwards.
VF38
Twin scroll turbo with titanium turbine and shaft. Smaller compressor housing than VF36/VF37 provides tremendous spool up capabilities but less top end than VF36/37. The spool capabilities of this turbo are demonstrated on the JDM Legacy GT, which reaches peak torque at 2400RPM.
See Subaru New Zealand - Technical Tips
VF39
Single scroll turbo used on USDM STI and latest 2.5L STIs released internationally. Smaller than VF30/VF34.
VF42
Exclusive turbo to the S203/S204 models, this features a twin scroll design with a slightly larger compressor than the VF36/37 turbos and different turbine design (more blades). The VF42 is a roller-bearing turbo and is likely of similar size to the VF22 turbo, but with twin scroll exhaust housing for faster spool and superior top end performance due to reduced exhaust pulse interference.
[ Dodano: 2010-03-24, 06:55 ]
Tłumacząc. Turbo na rolkach montowane w JDM-owej Imprezie STi. Zrobiona z tytanu z wydajnościa na 400KM. Wg mnie wstaje wysoko
- Coobcio
Tak tylko pomyliłeś VH36 z VH46 tu drugie to bardzo poplarna suszarka i starcza właśnie do ok 320KM maks przy czym cechuje się średnią lagowością w Subaru WRX 2002 i Legacy pełnego kopa daje już przy 4000obr.min
