[ Primera] P11-120 SE SR20DEH
Totenkopf
Re: [ Primera] P11-120 SE SR20DEH
Post autor: Totenkopf » 2019-01-25, 16:36
Puchacz pisze:
2019-01-25, 12:44
Knock sensor?
Yes.
VAZ 21013 - summer car
P11 SE SR20DEH AP0 - current
P11 GX SR20De AJ4 - sold
P10 LX SR20Di AG2 - sold
Puchacz
Post autor: Puchacz » 2019-01-25, 16:57
no spare Parts in Finland?
P11 GT Top Sport
P11 GT
P10 2.0 Invitation
P11 1.6 SLX
Totenkopf
Post autor: Totenkopf » 2019-01-25, 17:03
Puchacz pisze:
2019-01-25, 16:57
Only cheap aftermarket sensors which contain a 580kOhm resistor inside a nice plastic casing. The original costs probably more than my car.
Ostatnio zmieniony 2019-01-25, 18:54 przez Totenkopf, łącznie zmieniany 1 raz.
Post autor: janusz » 2019-01-25, 18:27
In Poland the new, OEM knock sensor cost 1500zł :d
Totenkopf
Post autor: Totenkopf » 2019-01-25, 18:53
janusz pisze:
2019-01-25, 18:27
I don't even want to imagine the current price in here. Probably the best example was the lower radiator hose which costs 110€.
Post autor: janusz » 2019-01-25, 22:41
The situation might be similar or reverse. The best example - oil. You pay 30-40EUR (120-160zł) per 5L, in Poland we'll paid circa 100EUR (400-430zł) for the same......
Totenkopf pisze:Probably the best example was the lower radiator hose which costs 110€.
In Poland the cost might be similar
piston rings set - 1000zł
guide-chain, tensioner side - 300zł
o'ring under the oil stand - 50zł
side airbag sensor - 1500zł
seal under the front windshield - 270zł
upper bar of the front windshield - 380zł
PCV valve - 260zł
Totenkopf
Post autor: Totenkopf » 2019-01-27, 11:35
janusz pisze:
2019-01-25, 22:41
PCV valve - 260zł
That sounds terribly similiar to the situation in here. New genuine parts are really hard to find here, since it appears that production has been ended for a while ago. Only some parts can be cross referenced.
Luckily our local aftermarket shop where I get my genuine oil has also stocked up with OEM oil filters now!.
https://m.motonet.fi/fi/tuote/159513?aj ... malli=1998
Priced at 11,90€, it's a bit cheaper than 15€ at Nissan dealership across the road.
