Yes.
[ Primera] P11-120 SE SR20DEH
Re: [ Primera] P11-120 SE SR20DEH
VAZ 21013 - summer car
P11 SE SR20DEH AP0 - current
P11 GX SR20De AJ4 - sold
P10 LX SR20Di AG2 - sold
no spare Parts in Finland?
P11 GT Top Sport
P11 GT
P10 2.0 Invitation
P11 1.6 SLX
P11 GT
P10 2.0 Invitation
P11 1.6 SLX
Only cheap aftermarket sensors which contain a 580kOhm resistor inside a nice plastic casing. The original costs probably more than my car.
Ostatnio zmieniony 2019-01-25, 18:54 przez Totenkopf, łącznie zmieniany 1 raz.
In Poland the new, OEM knock sensor cost 1500zł ![:d :d](./images/smilies/zeby.gif)
I don't even want to imagine the current price in here. Probably the best example was the lower radiator hose which costs 110€.
The situation might be similar or reverse. The best example - oil. You pay 30-40EUR (120-160zł) per 5L, in Poland we'll paid circa 100EUR (400-430zł) for the same......
piston rings set - 1000zł
guide-chain, tensioner side - 300zł
o'ring under the oil stand - 50zł
side airbag sensor - 1500zł
seal under the front windshield - 270zł
upper bar of the front windshield - 380zł
PCV valve - 260zł
In Poland the cost might be similarTotenkopf pisze:Probably the best example was the lower radiator hose which costs 110€.
PCV valve - 260zł
That sounds terribly similiar to the situation in here. New genuine parts are really hard to find here, since it appears that production has been ended for a while ago. Only some parts can be cross referenced.janusz pisze: ↑2019-01-25, 22:41The situation might be similar or reverse. The best example - oil. You pay 30-40EUR (120-160zł) per 5L, in Poland we'll paid circa 100EUR (400-430zł) for the same......
PCV valve - 260zł
Luckily our local aftermarket shop where I get my genuine oil has also stocked up with OEM oil filters now!.
https://m.motonet.fi/fi/tuote/159513?aj ... malli=1998
Priced at 11,90€, it's a bit cheaper than 15€ at Nissan dealership across the road.
can cialis be snorted
Abortion before first livebirth and risk of breast cancer <a href=http://cialis.lat/discover-the-best-pri ... lis>cialis 40 mg</a>
cialis liquid research
<a href=http://cialis.lat/discover-the-best-pri ... cialis>buy real cialis online</a> Perhaps the most interesting finding regarding adrenal function in dogs with gallbladder mucocele formation was that a significantly greater number of dogs had measureable and measurably higher concentrations of dehydroepiandrosterone sulfate DHEAS compared to control dogs
