[ Almera] N16 SR20VE - 2nd life
Totenkopf
Post autor: Totenkopf » 2017-11-17, 04:41
I was just wondering, out of curiosity, that how do your authorities deal with engine swaps such as this? In here it's pretty much illegal. If you were to inspect the car without the inspector noticing the new engine, you would get in serious trouble with the insurance company in case of an accident.
VAZ 21013 - summer car
P11 SE SR20DEH AP0 - current
P11 GX SR20De AJ4 - sold
P10 LX SR20Di AG2 - sold
Boro1989
Post autor: Boro1989 » 2017-11-17, 05:23
Totenkopf, nobody cares, :) you can have any engine as you want:)
Totenkopf
Post autor: Totenkopf » 2017-11-17, 06:26
I suddenly began to feel like moving to your country. Everything that is considered fun arouns here is either illegal, too expensive or bad for your health.
garygary
Post autor: garygary » 2017-11-17, 07:35
Totenkopf, engine is like any other spare part here, just like you changing a tire ;) there is some regulations about it i think but like Boro1989, says, nobody cares
Totenkopf
Post autor: Totenkopf » 2017-11-17, 07:43
That's the point, nobody cares. Here everybody cares a bit too much. Since the VE engine is not EC approved, it is nearly impossible to install it legally here. Well, it is, but I can think of many better things to spend 3000&#8364; than to a inspection that is unlikely to pass.
onyxx
Post autor: onyxx » 2017-11-20, 12:27
Ad@mus pisze:Ecu z n16 miało sterować tematem klimy w almerce. Cały silnik korzysta z ecu sunnego. A DET TO OSZUKUJE.
Tak więc.... build not bought ;) To nie był swap z DE na VE. To był jeden z pierwszych swapów z QG na SR. Sam to robiłem i powiem szczerze..... newer ever!
ECU z N16 nie jest potrzebne, żeby sterować klimą ;)
Ad@mus
Post autor: Ad@mus » 2017-11-20, 12:55
Ano nie trzeba, ale tak Gwaltek próbował sobie poradzić z tym tematem ;)
Tylko tłumaczę, dlaczego tam komp z n16 i że można go śmiało wyciąć ;)
lgruca
Post autor: lgruca » 2017-11-20, 16:06
onyxx, to co w takim razie jest potrzebne? Zastanawiam się nad koniecznością posiadania klimy i wolałbym ją zostawić of course, ale nie jest to konieczność.
onyxx
Post autor: onyxx » 2017-11-21, 01:48
Przepraszam ale nie za bardzo rozumiem pytanie...
Po prostu ECU silnika N16 nie jest potrzebne. Nie wiem co mam więcej napisać...
Ad@mus
Post autor: Ad@mus » 2017-11-21, 11:27
lgruca, Ja u siebie w Czarnej klimę na krótko podpiołem na chwilę. Przekaźnik na kompresor + przekaźnik na wiatak i powinno być w opcji bynajmniej manualnej. Sterowanie obrotami to już inna bajka ale w w/w opcji można używać w trasie a w korku rezygnować lub ustawić na krokowcu gazowym wyższe jałoe.... nie wiem, nie znam się.
lgruca
Post autor: lgruca » 2018-01-10, 23:41
Trochę odgrzewam kotleta.
Udało mi się porobić parę rzeczy - generalnie obie n16 są wybebeszone zarówno pod maską jak i pod deską.
Teraz czekam na parę frutów i będę mógł wkładać silnik do świeżego nadwozia.
Asekuracyjnie postanowiłem przerzucić klimę, abs i elektrykę.
W rudej dodatkowo zrobiłem konserwację przodu, a w ten weekend polecę tył.
Mam trochę pomysłów na małe zmiany pod maską i nie tylko, ale pewnie minie jeszcze chwila po poskładaniu zanim je zaimplementuje.
foo
Post autor: foo » 2018-01-12, 14:19
Up bez fot to nie up... nie ma tlumaczenia ;)
hyzios
Post autor: hyzios » 2018-01-15, 08:43
I ja coś dorzuce:
foo
Post autor: foo » 2018-01-15, 12:02
Nooo i pro. Zdrowo ta komora wygląda w rudej :)
lgruca
Post autor: lgruca » 2018-01-15, 18:41
foo, buda ma generalnie trochę nalotu i nic z poważniejszych rzeczy.
Modzelitto ją nawet oglądał i można powiedzieć że był pozytywnie zaskoczony stanem.
ale fabryczne zabezpieczenie antykorozyjne to jakiś żart.
Modzelitto
Post autor: Modzelitto » 2018-01-18, 15:02
lgruca, widziałem, macałem. Faktycznie jak na 18 letnią budę jest zdrowo. I powiedzmy sobie szczerze- oprócz elementów podłogi pod przednimi fotelami i miejsca pod bakiem- tam nie ma konserwacji fabrycznej. W profilach zamkniętych również nie ma kropli wosku. Ogólnie łapy opadają, ale całe szczęście masz fajną budę na którą trzeba położyć dobrą chemię i uzbroić w tylne nadkola.
Pozdr.
lgruca
Post autor: lgruca » 2018-01-24, 22:52
Z racji, że już po 22:00 kolejna porcja fotek z postępu prac:
położona wiązka komory
wiązka wnętrza również na miejscu
przełożony zawias z czarnej z wymianą wszystkiego co się dało, żeby już tam nie zaglądać przez pewien czas
pompa hamulcowa wraz z serwem z Patrola
no i na koniec drut mod - poduszki w masie poli - cała kolekcja
p.s. zawsze mnie bawi porównanie seryjnej tarczy z tą z murano. różnica jest "delikatna"
Seba WWA
Post autor: Seba WWA » 2018-01-24, 23:41
Teraz wkładać silnik i można śmigać. Reszta jest do dopieszczenia.
foo
Post autor: foo » 2018-01-25, 12:57
No i pięknie, ależ kusisz by rozpocząć jakiś prodżekt!
Daaaaamn... a myślałem, że się z tego wyleczyłem :)
lgruca
Post autor: lgruca » 2018-01-25, 19:07
foo, z tego co widzę masz silnik, więc czemu nie ;)
foo
Post autor: foo » 2018-01-25, 19:29
A to prawda swapik leży, tylko co jaką bazę oglądnę, to albo ulep blacharski, albo rdza, tudzież mix obu <shock> Ciężko o zdrowe almejro n15 4d
Baleron & Olo SSS mnie rozpaskudziły, iXiora też niezgorszego trafiłem, no wybredny się zrobiłem...
lgruca
Post autor: lgruca » 2018-01-25, 21:32
foo, ja szukałem prawie rok, aż trafiłem na rozbitka. i niestety musem było n16 bo elektryka i inne tematy podpasowane pod tą furę.
Ad@mus
Post autor: Ad@mus » 2018-01-31, 00:13
Foto nie działają mi :(
Foo, budę od Negry bierz :)
arczar
Post autor: arczar » 2018-01-31, 17:56
Ja mam dobrą czarną P11 przedlift HB 2.0 z przebiegiem 139000. Foty na PW (kiepskie, bo moje życie kiepskie)
Hobbysta Japanista
lgruca
Post autor: lgruca » 2018-01-31, 22:19
Ad@mus, foty nie działają bo się limit wyklikał :/ muszę je przerzucić na imgur czy inną zdjęciownie
btw. ruda pojechała dzisiaj do blacharza na małą robotę - pasowanie przodu i powoli będzie można ją kompletować, bo wszystkie graty już mam :D
Ad@mus
Post autor: Ad@mus » 2018-02-01, 12:46
Dawaj foto na gogle+ i nie zniknie. Daj na FB albo maila bom ciekaw co tam działasz.
lgruca
Post autor: lgruca » 2018-02-01, 23:05
Ad@mus, coś tam powoli się składa, nie ma co szaleć. ważne by zrobić na porządnie, bo z czarnej drut wystawał z każdego miejsca. ostatnio (jakieś 2 dni temu) w ręce rozsypała mi się prawa półoś - przegub wewnętrzny poleciał w kulki.
Ad@mus
Post autor: Ad@mus » 2018-02-02, 21:19
A elementy rudej bedziesz wtawiał na pod kolor czy masz jakieś inne plany ? :D
Harlekin+wrapping w przyszłości? Albo jakieś plasticipy/>
garygary
Post autor: garygary » 2018-02-03, 08:27
lgruca, jak robiłeś poduchy, to wycinałeś starą gumę, czy tylko dolałeś klejem?
